Slowing increase pressure inlet to get steady-state convergence?
Old   March 29, 2019, 14:13
Default Slowing increase pressure inlet to get steady-state convergence?
OH
flow-mo-mcfadden is on a distinguished road
Hi folks, I'm assessing the steady state condition of a primary and entrained flow in a pipe using Ansys Workbench with Fluent (v19.2). If I initialize (default hybrid initialization) with my primary flow at my desired pressure (2,000psi), the solution diverges. However, if I initialize at a 1,000psi BC, execute, let the solution converge then double the pressure inlet to my desired value and continue the calculation, then I get good convergence. I've tried a number of things (I'm very untrained with CFD mind you) including solution steering and have not been able to get convergence right off the bat.
In exploring the manual, I found that under "Calculation Activities" there seems to be a way of adjusting the inputs midway through the execution. Anybody have a hint on how I could change my pressure inlet value BC. I want to avoid the "man-in-the-loop" as I'm hoping to do a design optimization study involving a couple hundred iterations. Again, its steady state so the fact that I'm having this issue may be caused by something else.
flow-mo-mcfadden is offline   Reply With Quote
Old   March 29, 2019, 16:05
Lucky
You have to learn the text commands (the TUI commands). Press enter to see all available TUI commands.
A faster way might be to google/search for a Fluent journal file to get some ideas on what these commands might look like.
It will look something like:
/define/boundary-conditions/ blah blah blah
Yet another way could be to just record a macro.
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 10:34
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Pressure Inlet: question about total pressure I-mech FLUENT 0 July 13, 2014 05:38
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 09:20
error message cuteapathy CFX 14 March 20, 2012 06:45
