Is there any way to see time step in the temperature contours? |
March 29, 2019, 23:17 |
Aja
Rep Power: 14 |
I am simulating a transient model in ansys Fluent Separately(not from workbench). Now I want to export temperature contour in different time steps, But I can't create(or see) results with time step. Is there any way to see time step in the temperature contours? I am grateful that guide me in this case. Thanks. |
March 30, 2019, 15:42 |
Lucky
Rep Power: 65 |
Do you want time-step or flow-time? Because isn't there a window that always displays the flow-time?
There is an example here of how to create annotations to show the flow-time but usin cx macro's that I don't like. You can just replace flow-time by time-step if that's what you want. The idea is create an annotation that displays the variable. However, the annotations are static and so you must use the execute commands to update the annotation every time-step. |
April 1, 2019, 10:20 |
Moritz Kuhn
Rep Power: 17 |
In Ansys 19.1 go to the tab "Viewing" --> first section "Display" --> Options and then under Layout tick the box "Titles". Then you will get the flow time (not time step) in the plots (only for transient solver). If you want to export contours for different time steps you have to save data files for these time step or you can use the "Solution Animation" to produce the plots during the solution process (faster and with less data usage)
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
Time Step Continuity Errors simpleFoam | Dorian1504 | OpenFOAM Running, Solving & CFD | 1 | October 9, 2022 09:23 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
