March 29, 2019, 17:53 |
NASA Rotor 67 Fluent
Carlos Calixtro
Rep Power: 7 |
I am working on a project where I am using Fluent 19.1. I have a NASA Rotor 67 Mesh. I am having trouble finding convergence on my adiabatic efficiency. I am able to attain ~65% adiabatic efficiency. I have tried to set up my model various methods, but seem to be having problems.
I initially ran a mass flow inlet with a pressure outlet. My inlet conditions at 101,325 Pa, 288.15 K, and Mass Flow of 33.25. My outlet conditions are 121600 backflow total pressure, 288.15 K. Both inlet and outlet directions are normal to boundary. I set the problem up as a frame motion, used Steady and Transient time steps, Pressure-Based, and Relative reference frame for the solver. I am Using K-Omega SST. Would you have any recommendations to improve my adiabatic efficiency? I also have tried to run an inlet pressure and outlet pressure, with target mass flow, using a density solver but having issues with convergence of mass flow. Does Fluent divide the mass flow by the sector angle, or would I need to input the Mass Flow for the individual passage? Any recommendations would be great. |
April 3, 2019, 10:49 |
Luka Vincekovic
Rep Power: 7 |
Can you please describe how did you set up the rotation and mixing planes? Could you maybe share the case files? |
April 3, 2019, 11:25 |
Carlos Calixtro
Rep Power: 7 |
See files and result in the following folder. I also placed an example paper on a similar analysis in CFX. I have been unable to do a Pressure inlet and Outlet.
https://drive.google.com/open?id=15S...4sIG34yspToaxj |
April 3, 2019, 11:44 |
Luka Vincekovic
Rep Power: 7 |
I just had a quick look and one of the first thins I noticed is that you have huge y+ numbers. So just to see if this is an issue I would run this as pressure based coupled k epsilon with standard wall functions. See if this changes something. If not, try to refine the mesh around your "shaft" and start from there. |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 16:17 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
