April 6, 2019, 11:25 |
reaction mechanism in fluid domain
Weiqiang Liu
Rep Power: 9 |
hi all,
I am doing a micro-channel catalytic combustion of methane. All gas phase reactions are removed and only surface reactions are kept. After I imported all chemkin files, I found the reaction tab of fluid domain in cell zone conditions panel is enabled automatically and the mechanism is just the surface mechanism of my model. my question is should I disable this reaction tab in fluid domain because obviously there is no reaction in fluid domain or should I just keep it for it has no effect on results. Best. weiqiang |
fluid domain, mechanism |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 21:05 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Different diffusivity for additional variable in Fluid and porous domain | ftab | CFX | 4 | June 27, 2012 13:03 |
