Calculating torque in a FSI wind turbine simulation |
June 1, 2019, 12:53 |
Alejandro Valeije
Rep Power: 11 |
Hello everyone,
I have a question in which I have the feeling that it is more an issue of understanding the problem reather than the software itself. I'm running a FSI transient simulation of a wind turbine. Wind goes through the blades, and the blades and the domain in which they are contained move (the complete domain is divided in 2, a rotor domain and an extranal one). When it comes to calculate the rotated angle and velocity, there is no problem. But I would like to calculate the Moment (or torque) made by the turbine. I have tried to calculate it through a report, and with the Report function, and I get a value close to 0. I understand that, since no resistance is oposing to the movement, there is no force made, but there is any way of calculating the torque in this particular problem?? Thank u so much in advance for your help. Regards, Alex |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 06:13 |
shaft power versus RMP curve in wind turbine simulation | zhenduan306 | CFX | 28 | November 8, 2012 10:11 |
2D Simulation of Savonius Wind Turbine | ravindersingh | FLUENT | 4 | December 9, 2011 13:00 |
Problem with interface in a wind turbine simulation | be_inspired | FLUENT | 2 | March 7, 2011 23:46 |
