External force 6DOF
Old   July 24, 2018, 04:48
Unhappy External force 6DOF
HHOS is on a distinguished road
I have a very easy to picture 2D case. Two flat plates pushing together some fluid drop. One plate is stationary and the other is pressing with a constant force.
I have tried to solve it in two different ways.
The first, which should be the easier one, defining in fluent a spring only with a preload value. It didn't work.
On my second approach, I used the following UDF.
#include "udf.h"
DEFINE_SDOF_PROPERTIES(force_stamp, prop, dt, time, dtime)
	prop[SDOF_LOAD_F_X] = 0;
	prop[SDOF_LOAD_F_Y] = -500;
	prop[SDOF_MASS] = 1;
	prop[SDOF_IXX]  = 0;
	prop[SDOF_IYY]  = 0;
	prop[SDOF_IZZ]  = 0;
   	prop[SDOF_ZERO_TRANS_X] = TRUE;
	prop[SDOF_ZERO_TRANS_Z] = TRUE;
	prop[SDOF_ZERO_ROT_X] = TRUE;
	prop[SDOF_ZERO_ROT_Y] = TRUE;
	prop[SDOF_ZERO_ROT_Z] = TRUE;
   printf ("\n2d_test_box: Updated 6DOF properties");
I know that the dynamic mesh options are correct, because I already moved the wall with a velocity profile.
In both cases I defined a mass of 1 kg, because it gives an error with a mass of 0.
I hope somebody can give me a hand here.
Thanks.
HHOS is offline   Reply With Quote
Old   April 22, 2019, 05:16
Saif Ullah
saifullahkhalid is on a distinguished road
As a = F/m, putting m = 0 will obviously generate an error in calculating the translatory motion parameters.
saifullahkhalid is offline   Reply With Quote
6dof, dynamic mesh, external force, fluent
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
CompressibleInterDyMFoam with 6DOF body External Force im_lenny OpenFOAM Programming & Development 0 January 30, 2017 11:38
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 07:26
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Force can not converge colopolo CFX 13 October 4, 2011 22:03
