dealing with complicated chemistry with fluent |
Weiqiang Liu
Rep Power: 9 ![]() |
Hi all,
I am doing a catalytic combustion of methane simulation with fluent. With surface mechanism only, I can reproduce literature results. However, when gas mechanism is included, problem occurs. Attached are my residuals and monitored variable. The residuals are never decreasing and oscillating. So is the monitored variable, in specific, outlet temperature. I am wondering any strategies to get converged results in fluent when dealing with complicated results or some settings of my model are wrong? Please help. Best. Weiqiang |
convergence, gas mechanism, surface mechanism |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
The problem of Stiff Chemistry Solver in Multiphase model | shenzhou1987 | FLUENT | 1 | January 11, 2016 02:52 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 16:17 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
Flow interaction per chemistry update in FLUENT . | peter gelblum | FLUENT | 3 | February 6, 2003 03:43 |
