May 2, 2019, 13:42 |
DPM problem
Cristián Vera
Rep Power: 7 |
I simulated a transient fluid in a nozzle in ANSYS 18.2, the results about this simulation are ok. Now i want to add particles of aluminum (which already set up) but when I'm going to display the Particle Tracks the console just show me the message "DPM Iteration ...." and nothing appear. I don't know what could be the problem, I followed all the steps from the tutorial about DPM. Just to be clear, I'll show you the steps I followed after the fluid solution converged (with images): 1) 2) 3) 4) 5) 6) (I'm not used to use forums, sorry if I made a mistake) Thanks! |
May 2, 2019, 19:24 |
Cristián Vera
Rep Power: 7 |
last image added
May 3, 2019, 02:09 |
Alexander
Rep Power: 34 |
look at min/max particle diameter size, something is wrong with your solution
best regards |
May 4, 2019, 11:22 |
Cristián Vera
Rep Power: 7 |
ansys, dpm, injection, iteration, problem |
Can I solve MRF problem with DPM (Discrete Phase Model) ? | aminem | OpenFOAM Running, Solving & CFD | 2 | July 1, 2020 18:04 |
a strange problem on DPM model | zhengjimi | FLUENT | 1 | March 3, 2015 11:44 |
DPM mass source problem | maazulmosaid | FLUENT | 0 | April 25, 2014 06:25 |
DPM Output Problem (Again...) | DLINSA | Fluent UDF and Scheme Programming | 1 | March 16, 2012 00:45 |
Problem in DPM | Harpreet | FLUENT | 0 | July 31, 2011 09:56 |
