How to create multiple contact detections in dynamic mesh |
May 6, 2019, 06:28 |
Marcin
Rep Power: 9 |
Hi everybody,
Im performing the Fluent 6DOF simulation of the two valves rotating under the fluid flow. The movement of each valve is constricted to the specific maximum and minimum angle. There is a possibility of usage the Contact detection with the UDF define_contact. However, as far as I know there is not possible to impose two different UDFs, which is necessary, because the limits for each valve are different. Is there any possibility, for example by TUI, to impose several different contacts? Or - how to do some "work-around"? Regards Destroy |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
