May 7, 2019, 06:11 |
Flow around a triangular cylinder
Ujjwal Mohanty
Rep Power: 8 |
Hi guys,
I am trying to simulate flow over a heated equilateral triangle at Re 500 in fluent. Is using laminar unsteady model for this study correct? Regards, Ujjwal Last edited by ujjwalmohanty; May 7, 2019 at 06:13. Reason: adding tags |
May 7, 2019, 11:25 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
It is quite difficult to say if such geometry generates large turbulence in the separation region. Try a laminar setting using a 2D geometry and then check the same solution in a 3D gemoetry, for example using periodic conditions in the spanwise direction. Compare the solution to first assess if 3D effects are relevant or not. |
Drag force coefficient too low for a flow past cylinder at Re= 1e05 | Scabbard | STAR-CCM+ | 2 | June 5, 2020 14:44 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
