Errors running Fluent on HPPC
Old   May 7, 2019, 10:22
Unhappy Errors running Fluent on HPPC
Hamps's Avatar
Hampus Olsson
Hamps is on a distinguished road
Hi all,
I'm trying to simulate non-premixed MILD combustion in a laboratory combustor. I'm running steady state using the Realizable k-epsilon model for turbulence and Eddy Dissipation Concept (EDC) for turbulence-chemistry interaction. I am using a well known global 4-step methane-air mechanism with 7 species to try and investigate different model constant setups. Reaction rates are calculated using the Chemkin solver with ISAT.
My simulations run fine on my local machine (although slow), however, when I run them on our cluster, things start to get weird. The simulation will run for a while, sometimes less than an hour, sometimes over ten hours at 100 cores. The residuals are dropping nicely without any large oscillations when suddenly the solver crashes, giving the following error:
ellu_radii: bad singular value
I have been in touch with our cluster support and they say it's most likely some memory-related problem with Fluent, as opposed to the cluster itself. Oddly, I have run simulations without chemistry, as well as with the non-premixed combustion model without any issues previously.
My desktop runs windows and the cluster is Linux, so to start simulations on the latter I have done the following:
1. Write case and data files as non-binary (turn off binary checkbox in file-write)
2. Upload to cluster
3. Change linebreaks from dos to unix by running the dos2unix command on all files (.jou, .cas, .dat, as well as chemkin files)
4. Run simulation
Is there some step I am missing when converting from Windows to Unix files, or is anybody else familiar with the error? A google search doesn't yield anything, although the name indicates that it is related to some singular matrix in the solver.
Would be grateful for any insight!
“We demand rigidly defined areas of doubt and uncertainty!” - Douglas Adams
Hamps is offline   Reply With Quote
Fluent exit frequently with error ‘Unable to parse’ running on remote clusters Gang Shen Fluent Multiphase 5 February 7, 2022 03:02
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 15:01
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
