Why aren't the obtained boundary condition equal to the experimental boundary cond.? |
May 10, 2019, 07:48 |
Rep Power: 8 |
Guys,
I'm trying to validate my simulation which has been done by Fluent. So, I chose this article to validate my simulation. https://arc.aiaa.org/doi/10.2514/6.1997-65 Here is the experimental setup and design guide for bump body http://uupload.ir/files/l3hp_1-1.jpg Here is some explanations to the measurment: http://uupload.ir/files/jd5_2-1.jpg Here is specifictions of the wind tunnel: http://uupload.ir/files/gwzq_3-1.jpg Here is schematic of model and test section: http://uupload.ir/files/ratw_4-1.jpg Here is schematic of data aquisition and pressure tapping: http://uupload.ir/files/9oqf_5-1.jpg Some results for roughed wall: http://uupload.ir/files/chh4_6-1.jpg Because of some ambiguities, chose this article to design the domain and choose proper boundary conditions. https://www.tandfonline.com/doi/abs/....2010.11015308 As said in this part, designed the domain and specified the boundary condition as pressure inlet and pressure outlet: http://uupload.ir/files/wt8_7-1.jpg And specified inlet total temp. and pressure 310K and 140kPa respectively and outlet pressure 66kPa and Roughness height 580 micrometer and ran the computation. The results showed that the location of shock(using pressure distribution) is far away than the experimental results and the numerical simulation in the above article. I'm a little bit surprised because didn't expect to get such result. Also, the Mach number is lower/higher than 0.73. Questions:
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
how to impose experimental data as boundary condition in Fluent 6.3.26 | duina | Fluent UDF and Scheme Programming | 7 | March 6, 2015 08:45 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Velocity profile boundary condition | Tuca | FLOW-3D | 1 | April 23, 2013 12:02 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
