Why the continuity residual is not converging in inviscid flow? |
June 13, 2019, 14:05 |
Arijit Saha
Rep Power: 7 |
I ve been using Fluent to do a simulation of 2 airfoils seperated by some distance(problem statement) in inviscid steady condition. At the beginning I kept the relaxation factor as default but the continuity residual is not converging hence oscillating a lot. Even in the Cl monitor the Cl curve is not damping. Reducing the Pressure and momentum relaxation factor not solving the issue. The skewness and aspect ratio is also under control
So if anyone tells me how to troubleshoot this problem it will be of great help. |
June 19, 2019, 01:50 |
Jiri
Do you use double precision? My experience is that double precision usually improved the continuity residual significantly.
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
