Cyclic Symmetry and Periodic Boundary Conditions |
June 15, 2019, 06:12 |
Anonymous
Rep Power: 6 |
Dear all,
I have modelled a slice of a turbine and intend to model the entire turbine using cyclic symmetry. My results don't appear to show the flow of fluid across periodic/cyclic boundaries. Also, I do not know how to view the full scaled model of my turbine, is there a way to reflect the cyclic segments of my model? I have performed the following stages: 1. Assigned cyclic symmetry regions on the high and low boundary (left and right internal segment faces). Referencing a cylindrical coordinate system at the origin. 2. Assigned 'match control' mesh at the high and low boundary faces. 3. Entered fluent and assigned periodicity at the high and low boundaries using 'grid/modify-zones/make-periodic' command. The response in the command window was successful and formed one periodic boundary condition. Have I missed any stages? Using: ANSYS FLuent |
June 15, 2019, 12:50 |
Lucky
Rep Power: 66 |
You'll only get the results of the slice because that's what you are solving.
If you want to see the full 360°, you have to do some post-processing. Google some youtube videos on periodic repeats and look for this part in the manual. Your model is not full scale, it's a slice. In the future if you want the full scale model, then simulate the full scale model. There's a difference between reality and wishful thinking. Okay I get there are obvious reasons why you would want to simulate a slice instead of the full sector, but that is not an excuse to manipulate the language into something that it is not. =) |
June 15, 2019, 13:56 |
#3 | |
Anonymous
Rep Power: 6 |
Why am I using symmetry? I save an 11th of the computational expense if I can succeed in applying cyclic symmetry, which will be significant by the time I simulate rotational multi-phase flow. I've been trying to establish the difference between cyclic and period symmetry, they may both be suitable in my case - perhaps you're able to clarify? |
June 17, 2019, 13:12 |
#4 | |
Lucky
Rep Power: 66 |
You need to take a deep breath.
There are only two boundary conditions in Fluent. Periodic and symmetry. Symmetry is not for you. All the other fancy words you use are not Fluent but for the mesher (or perhaps even completely made up by you). Quote:
????? I didn't say anything about symmetry. Are you having a conversation with someone else? |
June 18, 2019, 16:41 |
Anonymous
Rep Power: 6 |
I hadn't distinguished these things between Fluent and Mesher, but clearly you aren't familiar with them. The periodic symmetry is referring to your slice or full sector comments.
June 18, 2019, 20:46 |
Lucky
Rep Power: 66 |
Yes clearly I'm not familiar with them.
November 18, 2019, 10:41 |
CFD-Lee
Rep Power: 6 |
Hi, Yorkshire.
Recently I've been working with cyclically periodic symmetry using Ansys Meshing as mesher and Fluent as Solver. I accidentally obtained expected mesh by following steps: 1. Inserted 'Pre-meshed Cyclic Regions' in Meshing, named face boundaries and coordinate system and gave the number of repeats. 2. Inserted 'Mesh Match' for two mentioned faces. 3. Generated Mesh and loaded it into Fluent, you should have an automatically coupled boundary naming something like 'periodic' with its type set as the only existing option 'periodic'. Why accidentally? Because till now I failed to redo this process!!! SAD and depressed. My version is 2019 R2. |
November 18, 2019, 14:46 |
#8 | |
Alexander Li
FLUENT Periodic Boundary Condition SOLVED + TUTORIAL |
cyclic boundaries, periodic boundary, symmetric mesh, turbine blades |
The interfere of Periodic with symmetry boundary conditions | Eirene2016 | Main CFD Forum | 0 | July 22, 2016 05:20 |
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 02:18 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Periodic Vs symmetry Boundary conditions | Amoul | CFX | 3 | June 7, 2013 00:02 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
