[ANSYS Fluent] Floating Point Error
Like Tree1Likes
  • 1 Post By ngoctm
Old   June 30, 2019, 15:39
Default [ANSYS Fluent] Floating Point Error
Georg
student123123 is on a distinguished road
Hello Fluent Forus,
I'm currently preparing my MSc Thesis on 'CFD Simulation of Submerged Water Jet Impinging on a Mobile Bed' but before that simulation I need to consider a simpler case of a submerged circular free jet (2D) and graph its velocity vs distance from the nozzle. I'm currently stuck on this simulation because the axissymetric simulation is giving me the program is telling me there is a 'Floating Point Error' (this does not happen when I consider the planar case).
I've checked the meshing (element size = 0.005m) and the boundary conditions (velocity inlet, pressure outlet, wall, and symmetry) and it doesn't look like there is a problem.
Inlet Velocity: 5 m/s (Reynolds ~150,000
Turbulence Intensity: 3.6 %
Turbulence Model: k-epsilon Standard
Thank you for your time and help.
student123123 is offline   Reply With Quote
Old   July 3, 2019, 03:14
ngoctm is on a distinguished road
In Fluent, a 2D-axisymmetric calculation needs a geometry on the XY plane, with the axis on X-axis and showing positive Y-values.
With your axisymmetric simulation, I think that you don't remember to change type of BC at symmety boundary: "symmetry" to "axis".
racing_student likes this.
ngoctm is offline   Reply With Quote
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 02:03
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
