HTC on two sides wall
Old   June 26, 2019, 12:06
Default HTC on two sides wall
Igor Vidic
igor_vidic is on a distinguished road
Hello everyone,
Can somebody please explain me how Fluent solve heat trsnsfer problem on coupled wall. For example I am modeling fluid flow around cylinder with energy source in it. I don understand how fluent calculate heat transfer coefficient between fluid and solid. I read that coupling wall means that heat flux is the same on boundary and its shadow zone.
igor_vidic is offline   Reply With Quote
Old   June 26, 2019, 17:54
Lucky
The heat flux on both sides of the interface is the same on the coupled wall (via energy balance). On the fluid side, the energy transport equation is solved for temperature/energy. On the solid side, the heat equation is solved for temperature/energy. Eventually you can get a heat flux.
It's similar to solving the flow around a cylinder with a heat flux boundary condition, except that the heat flux is now a free variable and not a fixed value.
Heat transfer coefficient is a post-processed quantity that is calculated after-the-fact using the heat flux.
Old   June 27, 2019, 03:51
Igor Vidic
Thank you very much for your replay. Does it mean that solver calculate temperature values in every cell from these two equation (transport energy equation for fluid and heat equation for solid)?
How To Calculate Average Heat Transfer Coefficient in CFD-Post? Shomaz ul Haq CFX 16 November 24, 2019 18:57
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
PostProcessing Util for Wall HTC and Temperature trojax OpenFOAM Programming & Development 0 April 2, 2012 11:15
HTC and adiabatic wall Alba CFX 4 November 26, 2007 12:52
