Square Wave Profile
Old   June 18, 2005, 23:30
Default Square Wave Profile
manish mehta
Dear All,
How do I generate a square wave profile for a pressure inlet boundary condition? I tried FFT but there are some problems with this. I need this to be a discontinous flow, because my pressure needs to have a square profile from 0 psi to 180 psi. I do not know how to write this as a UDF code. Can someone please help me?
Thanks. Manish
Old   June 20, 2005, 10:40
Default Re: Square Wave Profile
david
Hi, I've incluced a modified version of a UDF I used to prescribe a time-dependent velocity at the inlet of a pipe. I've modified it quickly so check for errors.
To use this, either interpret or compile this UDF and go to define/boundary-conditions. Choose the face on which you want to use the pressure pulse and choose the UDF named "pressurepulse" in this case.
If you need more details, let me know.
Regards, David ---------------------------------------------------
#include "udf.h"
DEFINE_PROFILE(pressurepulse, thread, position) { real x[ND_ND]; float t, velocity,w,y,z; face_t f;
t = RP_Get_Real("flow-time"); w=floor (t); z=t-w;/* z is ranging from 0 to 1 in this case but the time variable could be modified */
if (z<0.4) pressure = 0; else pressure =180;
begin_f_loop(f, thread) {
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f, thread, position) = pressure;
} end_f_loop(f, thread)
Old   July 4, 2019, 20:02
Islam Hassan
Islam Hassan is on a distinguished road
Thanks David,
I have question regarding your UDF, how can I change the requecy in your code like if I need to create square wave from 0 to 90 PSI, and 90 PSI from 0 to 0.5 sec and it is 0 from 0.5 to 1., asn so on.
thanks in advance
Islam Hassan is offline   Reply With Quote
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 08:38
UDF for Square Wave Emmanuel FLUENT 2 March 13, 2010 08:36
Free surface water wave profile John N. FLUENT 0 February 2, 2009 16:17
UDF for square wave velocity profile..pls help Frederik FLUENT 0 May 8, 2006 06:48
udf_square wave profile Ramin FLUENT 0 March 8, 2006 09:38
