July 4, 2019, 05:23 |
named selection in ansys
far
Rep Power: 6 |
hi, is there any different between name selection with face and body in 3d problem?
my case is a 3d collector with glass, cover and insulated part.how should i named these parts? selecting face and then select all the face of collector,glass, cover and isulated part or select body and selecting 4 parts? |
July 4, 2019, 14:28 |
Amy M
Rep Power: 7 |
Hi far,
I think that you choose your name selection based on how you want to apply it in the next step. For example, your boundary conditions are likely applied to a specific face, and not a whole body so in that case naming faces would be better. If you are trying to specify a material property to a specific body, you would probably want to name a body. I think if you name all the faces of a body, you won't be impacting the interior of the body. Hope that helps |
July 4, 2019, 23:23 |
of course there is a difference
#3 | |
Ali Gürcan
Rep Power: 6 |
First of all, make a single part in Design Modeler and say Shared Shared Topology sonra then click erate Generate ya or if it is an assembly in SpaceClaim, don't forget to make Shared Topology by clicking on the assembly. Nodes are linked with each other |
ansys18.2, named selections |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
Generate Parts Using Named Selection | jonasohlsson | ANSYS | 1 | March 14, 2016 04:32 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Internal Surface Selection in Ansys Workbench using Script | arjunkothidar | ANSYS | 3 | November 13, 2014 01:07 |
Named selection - design modeler | jsm | ANSYS Meshing & Geometry | 0 | November 19, 2009 07:44 |
