Sectional lift and drag coefficients
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   August 2, 2022, 08:17
Default Sectional lift and drag coefficients
Duy-Nguyen
duybk2501 is on a distinguished road
Hi everyone,
I hope you are doing well these days.
I am running a three-dimensional simulation of flow over a circular cylinder using ANSYS Fluent. Now, I want to save transient data of the lift and drag coefficients of the cylinder at different cross-sections over its span (sectional lift and drag). I can only save the transient data of the total lift and drag of the whole cylinder surface, but what I want is the coefficients over the circumference of the cylinder at multiple planes. I have been looking for solutions for quite a long time but I haven't got an answer yet. Does anyone know how to achieve this? Your reply is much appreciated. Thank you for your attention.
Cheers.
duybk2501 is offline   Reply With Quote
Old   August 3, 2022, 00:48
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
no experience here
first come to mind :
you may create thick surfaceslocated at planes you are looking for, rerun simulation and extract the data
duybk2501 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 3, 2022, 08:24
Duy-Nguyen
Good idea, AlexanderZ!
I am thinking of creating a ring surface surrounding the cylinder at a plane of interest. As long as the thickness of the surface is small enough, it may be considered a circle. This approach seems to be handy and easy to achieve.
Another option is to define hundred of points surrounding the cylinder circumference in a plane. Then, manually calculate the lift and drag by integrating the wall shear stress and pressure with respect to the location of each point. This approach seems to be very demanding, but that is an alternative way I can think of.
Thanks a lot for your suggestion!
circular cylinder, fluent
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 06:04
How to extract Lift and Drag coefficients from Ansys Fluent Abdul_Rehman FLUENT 9 March 22, 2021 08:37
Lift and Drag Coefficients Too High SteveFRUCD STAR-CCM+ 1 September 30, 2019 09:27
How to not overwrite drag and lift coefficients after a simulation Giovanni Trovato FLUENT 1 August 1, 2018 00:31
Lift and drag coefficients of the NACA 0018 Volodymyr CONVERGE 4 September 22, 2017 17:52
