What is the boundary condition for shell and tube heat exchanger ? |
July 14, 2019, 01:52 |
Muhamad Miftahul Azhar
Rep Power: 6 |
I want to know the outlet temperature based on the data that is known. That's the geometry of heat exchanger (.iam / inventor), mass flow inlet (both fluid), inlet temperature (bot fluid), both my fluid are water. My model is consist of shell fluid domain, tube fluid domain, and tube.
I've did named selection for hot fluid nozzle inlet, hot fluid nozzle outlet, cold fluid nozzle inlet, cold fluid nozzle outlet, shell fluid domain body, tube fluid domain body, tube body. I've did boundary condition for mass flow inlet (both nozzle inlet) and pressure outlet (both nozzle outlet). What is the boundary condition for other part ? for example tube. In my case, heat transfer coefficient if unknown because outlet temperature is unknown. Thank you |
Boundary Conditions for Fin and Tube Heat Exchanger | tatianasf.94 | FLUENT | 0 | July 1, 2019 16:43 |
Defining Boundary Condition of Simulation of Shell and Tube Heat Exchanger ? | miftahazhar | FLUENT | 0 | June 26, 2019 10:34 |
Heat Flux Boundary condition | NightWing | FLUENT | 2 | April 3, 2016 22:34 |
Thermal boundary condition for a finned-tube heat recovery unit | Eirik | FLUENT | 0 | February 10, 2015 04:53 |
Boundary condition of the fluid type for tube-in-tube heat exchanger | Ashraf Mimi | FLUENT | 3 | January 9, 2015 07:17 |
