September 22, 2016, 08:27 |
Reactions with porous medium
Yuting
Rep Power: 9 |
Hi friends
Could Fluent implement the porous medium reacting with gas flow? I'd like to simulate the coal particle react with hot gas and assume the fixed bed of coal as porous medium, the hot gas will penetrate the coal bed and react with coal particle. Any body can give me some advices? Really thanks for the help..Please |
July 15, 2019, 14:06 |
Emerson
Rep Power: 7 |
I would like to know this too =/
July 15, 2019, 22:12 |
Yuting
Rep Power: 9 |
Hi, for the reactions involved in the porous medium, the possible solution is to write the UDF and UDS to describe the happened heat and mass transfer. Fluent itself seems does not provide the model access on the GUI. Hope this might help you.
July 21, 2019, 10:45 |
Weiqiang Liu
Rep Power: 9 |
I almost finished this project. However, the velocity contour is not very reasonable. Have you met same problem?
July 22, 2019, 01:08 |
#5 | |
Yuting
Rep Power: 9 |
I think there are many possible problems may cause the velocity contours unreasonable. For example, the incorrect boundary conditions including the porous medium properties, and the operational pressure, even the momentum source along with the mass source added into the porous zone. Maybe you can go back to check if these are correct and then modify your case. Hope this can help you. Yuting |
July 22, 2019, 11:15 |
#6 | |
Weiqiang Liu
Rep Power: 9 |
I spend a lot of effort on this problem. You just told me mass source term may take an effect? Will mass source term influence velocity field? Best regards. |
July 23, 2019, 19:56 |
#7 | |
Yuting
Rep Power: 9 |
Yuting Important: Note that if you define a mass source for a cell zone, you should also define a momentum source and, if appropriate for your model, energy and turbulence sources. If you define only a mass source, that mass enters the domain with no momentum or thermal heat. The mass will, therefore, have to be accelerated and heated by the flow and, consequently, there may be a drop in velocity or temperature. This drop may or may not be perceptible, depending on the size of the source. (Note that defining only a momentum, energy, or turbulence source is acceptable.) |
July 23, 2019, 22:43 |
#8 | |
Weiqiang Liu
Rep Power: 9 |
Thanks very much for your suggestion. I've been working on this for weeks and can not find solution. Yes, I have mass source term in the domain. However, I did not define corresponding momentum source. Thanks very much Weiqiang |
multiphase cylindrical flow through porous medium; BC | adrianabm | OpenFOAM Running, Solving & CFD | 1 | September 7, 2015 10:37 |
Velocity inlet boundary condition for porous medium | Chander | CFX | 3 | March 11, 2012 21:18 |
Lack of local thermal equilibrium in porous medium | Chander | CFX | 4 | March 4, 2012 04:07 |
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? | Chander | CFX | 3 | November 28, 2011 14:26 |
porous medium and reactions | Valeria | FLUENT | 1 | July 10, 2009 03:58 |
