6DOF: can't compute angular acceleration
Like Tree3Likes
  • 3 Post By Centurion2011
Old   June 17, 2009, 08:27
Default 6DOF: can't compute angular acceleration
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
I everybody,
When i use the following 6dof properties :
prop[SDOF_MASS]=0.0014;
prop[SDOF_IXX]=2.333333e-8;
prop[SDOF_IYY]=2.333333e-8;
prop[SDOF_IZZ]=2.333333e-8;
Fluent display the message :
Info: 6DOF: can't compute angular acceleration.
Check moments/products of inertia.
If i increase moments of inertia (1e-6 for example) the message disapear. Any idea ?
laurentb is offline   Reply With Quote
Old   January 5, 2011, 09:03
Default Fluent Limitation
W.N. Anderson
Will Anderson is on a distinguished road
The SDOF variables can only process solid body moments of inertia>=1e-06.
Unfortunately.
Will Anderson is offline   Reply With Quote
Old   December 12, 2013, 04:34
Centurion2011's Avatar
Centurion2011 will become famous soon enough
Unfortunately.
If this is correct than I am dissapointed in fluent developers
Also, when looking into 6 dof theory one cannot but wonder how brief it is. One could hope for better explanations about conservation of angular momentum equations (or Euler equations), specially since 6 dof solver is "solving" these equations using already establieshed numerical method.
I wrote with my friend our own "6 DOF solver code" in under 80 lines of code and it can calculate Euler angles (pitch roll and yaw angles) for bodies with body moments of inertia>=1e-06.
I'M NOT A GYNECOLOGIST BUT I'LL TAKE A LOOK.
Centurion2011 is offline   Reply With Quote
Old   March 26, 2015, 22:14
Post
Wei Liu
youiithe is on a distinguished road
Unfortunately.
Unbelievable! How come!
youiithe is offline   Reply With Quote
Old   October 23, 2015, 01:49
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
how to stop this message from appearing in Fluent TUI? As I don't want to calculate rotational motion (yaw, pitch or roll). And I am not using shear stress terms in Six DOF UDF.
Far is offline   Reply With Quote
Old   October 27, 2015, 03:05
Far
Sijal
do we need to provide torque (using speical command in UDF) to body or Fluent has some internal mechanism to calculable torque from the given forces?
Old   July 5, 2017, 04:21
SJSW is on a distinguished road
Was the option "implicit update" checked?
I have a similar problem after the implicit update was checked.
Sorry, I found that the reason is the moment of inertia was 0 and then angular momentum can't be calculated.
so far it has nothing to do with "implicit update".
SJSW is offline   Reply With Quote
Old   July 26, 2019, 12:54
amir parsa
amir_ip is on a distinguished road
Did anyone solve this problem?
amir_ip is offline   Reply With Quote
Acceleration in CFX Post LancelotCFD CFX 6 November 4, 2008 11:06
6DOF for flapping plate Mike FLUENT 0 March 6, 2007 01:25
Angular Discretization for 2d DO Model RAO FLUENT 0 April 18, 2006 05:40
How to compute an average slip velocity using DPM thomas FLUENT 0 February 9, 2004 08:17
Angular momentum conservation? Barry Main CFD Forum 19 April 11, 2002 10:37
