msh file format
Like Tree2Likes
  • 1 Post By fab
  • 1 Post By alireshad
Old   April 25, 2005, 11:59
Default msh file format
fab
I want to read a fluent 'msh' file with fortran. I made the mesh in 'Icem' and exported it.
To read the mesh with a fortran sequence, I have to know the structure, but unfortunately I just find an explanation about the 'cas'-file structure in the manual.
Does anybody have an idea, how the 'msh'-file structure looks like?
Greetings! fab
poptiger likes this.
Old   April 25, 2005, 14:24
Default Re: msh file format
Harish
The mesh file can be read by opening into word pad. It basically has tge grid points lines faces etc. That you created. Just erase everything else other than the grid points and import the file.
-H
Old   April 25, 2005, 18:24
zxaar
the format of meshexplained in cas file portion of manual is enough to read it, my code reads fluents mesh and only read the portion of manual
Old   April 26, 2005, 01:29
fab
as mentioned I saw the cas-portion in the manual before; I thought it just explains the cas-file which looks pretty different to my original msh-file.
As I understand it now, the cas-file has different sections and one is the section for the grid which does have the same structure as the msh-file. Right?
Actually, taking a look at some cas-file I just see binary stuff in the grid section, but I suppose it has the same format as in the mesh file ...
Would you mind to share the routine to read the msh-file?
Thanks!
fab
Old   April 26, 2005, 05:29
zxaar
yes the portion describing mesh in cas file is same as the msh.
this is the reason fluent reads cas/msh file from read->cas menu.
i can give u my code to read fluent mesh, but there are two problems, one the code is written in c++, and second the file is long becuase in the same file after reading the mesh i generate coarse meshes for implementing multigrids. this will confuse you. further the module is not so fast, because for readign mesh the hex number has to be converted and that takes time (in c++ otherwise we have a funstion of reading hex, but i am currently using c type i/o),
you can drop me an email i will send you the file that reads fluent mesh, see if u can make out of it.
Old   May 25, 2012, 07:45
ali reshad
alireshad is on a distinguished road
Originally Posted by zxaar
;120131
hi zxaar
please send me your code.i urgently need this code
ali.reshad68@yahoo.com
thanks
alireshad is offline   Reply With Quote
Old   October 14, 2014, 09:57
k
znri is on a distinguished road
Originally Posted by alireshad View Post
hi zxaar
thanks
Hi
I have a msh file that I have created with a software for generating porous models. I need to read it with fortran (or C++). But my msh file is binary and when I open it in wordpad , I can't see within the file. And the software hasn't any option for producing msh file. How I can I convert my msh file to ascii format? I want then use this msh file to fluent.
Any help would be appreciated.
znri is offline   Reply With Quote
Old   October 29, 2014, 11:03
abhishek
abhi158 is on a distinguished road
;120131
hi ...
i have gone through the post, i am also looking for a way to import ansys icem msh file in FORTRAN....
if nebody has a sample program or subroutine related.....can u please mail me abhibhesania@gmail.com .....
its quite urgent....
abhi158 is offline   Reply With Quote
Old   September 9, 2015, 12:42
Default Ask for the code read fluent mesh
William Yao
william.yao is on a distinguished road
I have read through the posts and I'm also struggling on how to read the msh file in FORTRAN. Could you please send me your code in reading .msh file in FORTRAN, Thank you, it's really appreciated. Email address: yaomin_yaomin@163.com
;120131
william.yao is offline   Reply With Quote
Old   August 26, 2019, 20:17
lyy07 is on a distinguished road
Here might be one:
http://oss.jishulink.com/upload/2016...e%20format.pdf
lyy07 is offline   Reply With Quote
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
