October 14, 2019, 08:44 |
Reversed Flow in Outflow?
jens meier
Rep Power: 6 |
Hey all.
I'm dealing with a dynamic mesh. I use the smoothing diffusion setting in order to let the mesh move uniformly. During the simulation the console says that there are reversed flows in my Outflows. How can I avoid this ? Or isn't it a problem ? Best regards |
October 14, 2019, 09:07 |
#2 | |
Rep Power: 13 |
How good is overall mass conservation with reversed flow? Generally speaking can reversed flows be avoided by extending the outlet region. |
October 14, 2019, 09:10 |
jens meier
Rep Power: 6 |
At the moment, I'm just simulating with water liquid.
Where can I find information about mass conservation ? I just don't understand because when I use the spring based method, I don't get reversed flows, but the mesh is getting so thin that I get floating point exception error. |
October 14, 2019, 09:27 |
#4 | |
Rep Power: 13 |
Regarding your question about spring based method i don't know what that is. Reversed flow comes from a vortex that is present at the outlet region (hence extending the outlet region) or by a faulty BC that creates a reflux from your outlet.. |
October 14, 2019, 09:32 |
jens meier
Rep Power: 6 |
Yes its transient.
Unfortunately I cannot change the geometry in order to extend the outlet. I have two outflows and two walls. symmetric |
October 14, 2019, 10:09 |
Rep Power: 13 |
Ok, i see. Then check the mass balance over the whole domain. Reversed flow at the outlet should not be a problem, as long as it's physical and not caused by boundary condtion itself.
October 14, 2019, 12:59 |
jens meier
Rep Power: 6 |
thank you very much for your answers!
Hope I will solve the problem |
outflow boundary condition | ravi_adepu | FLUENT | 11 | January 19, 2018 07:13 |
Diffuser reversed flow | macdhui | FLUENT | 4 | October 8, 2015 04:48 |
Reversed flow at pressure outlet | Seeker Phil | FLUENT | 9 | January 2, 2010 05:21 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
reversed flow | Sastry | FLUENT | 5 | March 22, 2007 08:05 |
