October 14, 2019, 16:08 |
Matlab-Fluent Interfacing
Amitav tikadar
Rep Power: 8 |
I am trying to interfacing between Ansys Fluent 2019R2 and Matlab. I can run my Fluent simulation via Matlab. Now I am trying to calculate mass weighted average temperature of a volume and I have used this Matlab command
iFluentTuiInterpreter.doMenuCommandToString('repor t volume-integrals mass-avg (channel) temperature n') This code can measure the temperature and can print the value in Matlab command window. But now I want to save this value in another variable so that I can use this number in post-processing. I am trying to use this command iFluentTuiInterpreter.doMenuCommandToString('defin e variable pick report volume-integrals mass-avg (channel) temperature n') but its not working. Can someone please help? Thank you. |
October 15, 2019, 00:05 |
Svetlana Tkachenko
Rep Power: 14 |
Would you like to set fluent to write this value to a file, and then read it in matlab? Or this would be bad for your case.
October 16, 2019, 17:03 |
Amitav tikadar
Rep Power: 8 |
October 16, 2019, 18:52 |
Svetlana Tkachenko
Rep Power: 14 |
If you tried to do this through an external file, would it work at all, or would it create issues with the timing?
October 16, 2019, 22:35 |
#5 | |
Amitav tikadar
Rep Power: 8 |
x=iFluentTuiInterpreter.doMenuCommandToString('rep or t volume-integrals mass-avg (channel) temperature n'); %it will save temperature as a string called x y=char(x); % convert x into a character .... Then I split the character and finally convert the appropriate character into a number. Thank you. |
fluent, matlab, matlab coding |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
linking matlab and fluent | Nair | FLUENT | 23 | January 12, 2020 18:55 |
How To Make MATLAB Apps For Fluent | behest | FLUENT | 0 | March 3, 2014 07:00 |
Creating UDF file in MATLAB for Fluent | ppa381 | Fluent UDF and Scheme Programming | 1 | October 10, 2013 09:27 |
Matlab for UDF's in Fluent | tejasvikrishna | FLUENT | 1 | September 9, 2010 07:28 |
