Tracking mass flow in & out
Old   October 20, 2019, 09:52
Default Tracking mass flow in & out
Science2108 is on a distinguished road
Hello everybody,
i have a system with a two phases: liquid and gas.
I have set a pressure inlet for the entering gas, so it can flow in and out through this inlet.
My question now: i want to track the mass flow in and out of the pressure inlet of the component gas. I found the report mass flux but i think this report only shows how much gas flows in but not how much gas flows out. Is that right?
I want to determine equilibrium with the report.
Thanks
Science 2108
Science2108 is offline   Reply With Quote
Old   October 21, 2019, 08:23
Moritz Kuhn
MKuhn is on a distinguished road
The report mass flux function reports the absolut amount of fluid passing this boundary. It can be positive (inlete) or negativ (inlet which acts as an outlet). If you have only one inlet, this mass flux must be zero in a steady state solution. If your inlet is in plane with e.g. XY you can easly create plots, to see where the mass flow goes in and where out.
I'm not sure, if this is a good model set up with only one inlet which acts also as an outlet.
MKuhn is offline   Reply With Quote
Old   October 29, 2019, 07:53
BlnPhoenix is on a distinguished road
My guess is you have one inlet set as pressure inlet and one outlet somewhere else.
If you have an inlet that acts also as a potential outlet, you can not determine each amount going in and out at the same time. You only get an total net flow (inlet - outlet), which is calculated by the mass flux function. What you need is an orientation on the patch. You can calculate the mass flows by calculating: velocity in flow direction * density * cell Area, so you end up with a mass flow with negative values (going out your domain) and some mass flow with posistive values (going in your domain)
Things get more complicated in a situation where you have mutiple phases because inflow and outflow for each phase does not necessecarily need to be the same in an unsteady situation.
BlnPhoenix is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
choked mass flow value pamstad CFX 2 October 2, 2019 03:02
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 11:46
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
