Retrieve value of Scheme variable in TUI command
Like Tree2Likes
  • 2 Post By p.b+cfd
Old   November 8, 2019, 11:49
Default Retrieve value of Scheme variable in TUI command
Mark Lytell
lytemar is on a distinguished road
I couldn't seem to find an answer to this particular type of problem. So here goes...
In a Fluent Journal, I would like to define a string constant that contains the root name of the case file so that I can use the same string in other TUI commands, e.g., setting the root name for auto-save, etc.. This is what I did:
; define the case/data file name root
(define casedatfileroot "./mdl-name-shell-cond-transient")
; define the case file path
(define casefilepath (string-append casedatfileroot ".cas.gz"))
These variables are defined, but when I try to read in the case file, using this command,
/file/read-case (rpgetvar 'casefilepath)
I get the errors:
Error: File "(rpgetvar" not found!
Error Object: #f
invalid command ['casefilepath)]
This is using Fluent 2019R3. Can someone please help me? The ANSYS documentation is essentially non-existent for this.
lytemar is offline   Reply With Quote
Old   November 8, 2019, 13:59
Lucky
Filenames are not evaluated in the text prompt system, they are the only exception.
I get the errors:
Error Object: #f
Fluent is looking for a file named (rpgetvar because this text is not being evaluated.
Here is a link to the non-existent documentation.
Old   November 8, 2019, 15:29
Mark Lytell
Thanks, so this is not possible? That's a bummer.
Old   September 18, 2020, 04:19
p.b+cfd is on a distinguished road
For the record
First option using scheme variable (only valid during the current session of Fluent):
; Quoted
(ti-menu-load-string (format #f "/file/read-case ~s") casefilepath)
; Un-quoted
; (ti-menu-load-string (format #f "/file/read-case ~a") casefilepath)
Second option using rp-variables (will be stored with the case):
(rp-var-define 'casedatfileroot "./mdl-name-shell-cond-transient" 'string #f)
(rp-var-define 'casefilepath (format #f "~s" (string-append (rpgetvar casedatfileroot) ".cas.gz")) 'string #f)
; Quoted
(ti-menu-load-string (format #f "/file/read-case ~s") (rpgetvar 'casefilepath))
; Un-quoted
; (ti-menu-load-string (format #f "/file/read-case ~a") (rpgetvar 'casefilepath))
To avoid typing these insanely long macros
(format #f "format string ~s" variable)
(ti-menu-load-string (format #f "format string ~s" variable))
all over the place I'd strongly recommend some global definitions like:
(define (fmt . args) (apply format (append (list #f) args)))
(define (tui . args) (ti-menu-load-string (apply fmt args)))
With these little macros defined, the first example could be reduced to
; Quoted
(tui "/file/read-case ~s" casefilepath)
; Un-quoted
; (tui "/file/read-case ~a" casefilepath)
while the second example could be simplified to
(rp-var-define 'casefilepath (fmt "~s" (string-append (rpgetvar casedatfileroot) ".cas.gz")) 'string #f)
; Quoted
(tui "/file/read-case ~s" (rpgetvar 'casefilepath))
; Un-quoted
; (tui "/file/read-case ~a" (rpgetvar 'casefilepath))
sfernaferna and zimao like this.
p.b+cfd is offline   Reply With Quote
Old   April 10, 2021, 14:15
Default typo?
Sócrates Fernández
sfernaferna is on a distinguished road
Send a message via Skype™ to sfernaferna
Hi, thanks for your contribution. My first time quoting, I hope to do it correctly.
For me, the format command (rpgetvar option) worked only if I include the (rpgetvar 'variable) inside the parentheses of the format command. I am referring to the lines:
; Quoted
; Un-quoted
As an example, here are my own commands, where I put the rpgetvar inside the format parenthesis:
(ti-menu-load-string (format #f "report/dpm-extended-summary yes casename_~a yes no" (rpgetvar 'flow-time)))
DID WORK .
However, the following DID NOT WORK:
(ti-menu-load-string (format #f "report/dpm-extended-summary yes casename_~a yes no") (rpgetvar 'flow-time))
With the error:
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
Hope it helps! If it was a typo then I'm happy to have helped. If it wasn't I would be very grateful to receive some explanation on why it worked for me.
sfernaferna is offline   Reply With Quote
Old   April 11, 2021, 22:47
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
that was typo
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
fluent, scheme language, tui command
How to save /adjoint/observable/evaluate result to scheme variable? ProBioticum Fluent UDF and Scheme Programming 5 October 8, 2019 08:55
[PyFoam] PyFoam 0.6.9 wrong path to gnuplot klausb OpenFOAM Community Contributions 5 March 15, 2018 14:28
I need help for TUI command ringtail FLUENT 3 September 8, 2010 10:31
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
