November 20, 2019, 23:11 |
Changing fluent default settings
sunil
Rep Power: 13 |
Hi All,
For most of my simulations, I will be changing a lot of fluent default parameters like pressure unit from pascal to psi, solution backup interval from 0 to 500, iterations to store to 5000, etc. How can I change these settings permanently so that every time I launch the fluent it will load with the modified setting. I heard that there is an option to edit a fluent.bat file to change the default settings but I am unable to find the details about that.
Regards, Sunil |
November 20, 2019, 23:58 |
Alexander
Rep Power: 34 |
make a journal file with all your settings
best regards ****************************** press LIKE if this message was helpful |
November 21, 2019, 08:42 |
Lucky
Rep Power: 66 |
Just in case you had any doubts. Make a journal file
November 22, 2019, 03:58 |
sunil
Rep Power: 13 |
Hi Tran,
thank you for your reply, if I make a journal file then how can run it automatically when fluent starts. Regards, Sunil
Regards, Sunil |
November 22, 2019, 10:33 |
Lucky
Rep Power: 66 |
You don't need to run it automatically, although you could.
When you launch Fluent, you can set it to run your journal. Or you can manually run it it (by just typing file/read-journal), or it's just 3 button clicks in the GUI. It's just the standard practice that everyone (that wants this level of control) has a journal file and runs it at some point. |
November 25, 2019, 00:16 |
Alexander
Rep Power: 34 |
journal file could be run automatically, however, I don't remember how to do this
as far as I remember, some folder should be created in working directory with special name that folder should contain your journal file with special filename extension
changing default |
Some settings were missing if exported from Hypermesh to Fluent | QQ1034914840 | FLUENT | 0 | June 19, 2016 15:04 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Fluent default surface boundary condition | lalupp | FLUENT | 2 | February 27, 2012 03:30 |
Changing default values | dcwnj | CFX | 1 | February 6, 2008 15:46 |
