Moment coefficient calculation in ANSYS Fluent
Old   December 17, 2019, 01:02
Default Moment coefficient calculation in ANSYS Fluent
oncernhan is on a distinguished road
Hi all,
I am doing a 2D CFD simulation for a vertical axis wind turbine (VAWT). I can calculate moment coefficient (Cm) versus flow-time for one revolution.
Then I tried to calculate moment based on the formula: M = 1/2rho*V^2*A*R*Cm
Does ANSYS Fluent calculate Cm based on the relative velocity between wind velocity (inlet velocity) and rotational velocity of turbine (V(t/g) = omega*R)? I tried to google it but it seems like no one has ever asked this question.
Thank you very much for your help.
oncernhan is offline   Reply With Quote
Calculating Coefficient of Drag in ANSYS Fluent osamaghani FLUENT 16 April 21, 2019 10:29
Calculation of Moment Coefficient andromeda91 SU2 2 December 11, 2013 12:59
Heat Transfer coefficient calculation using Ansys cfx rckbasha Main CFD Forum 0 March 7, 2012 02:17
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:51
