Continue transient via TUI Journal
Old   January 2, 2020, 23:40
Default Continue transient via TUI Journal
esma is on a distinguished road
Hi All,
I appreciate any input since my search online didn't go anywhere!
I 'm running a transient flow using Fluent on a HPC. So I've been using the journal commands below:
file read-case SYS-2.cas.gz
file read-data SYS-2-00000.dat.gz
solve dual-time-iterate 40000 85
file write-case SYS-2-1.cas
file write-data SYS-2-00000-1.dat
exit
yes
In my ANSYS Fluent setup, I had used Courant 0.9. Let's say at iteration 10000 the simulation has stopped and from error, I believe I need to control the time step by lowering the Courant no., now I'm trying to continue with a smaller courant number after 10000.dat file.
has anyone got experience with this to how to proceed and what command perhaps I should add to the Journal file.
Thanks
esma is offline   Reply With Quote
Old   January 3, 2020, 01:01
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
find out what exactly you want
to get courant number you can use
(rpgetvar 'pressure-coupled/courant-number)
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
transient journal file in fluent crispysalt FLUENT 0 January 5, 2013 21:10
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 23:01
EULER-Forward-Method freak Main CFD Forum 4 June 12, 2001 10:19
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 08:25
