Drag/Lift CO-efficient dependence on WT Cross-Section area |
January 7, 2020, 13:16 |
Usama
Rep Power: 6 |
I am calculating drag and lift coefficients of an object placed in a wind tunnel numerically.
I am using 2 different WT geometries. one is much larger like other is smaller. In order to see the experimental blockage effect. My question is: Does drag co-efficient depend upon the area of cross-section of the wind tunnel that I am using. Imagine placing an object once in a big box around it and other time in a small box. WT-1: 350mm W x 350 mm H with the length of 1meter WT-2: 2.2m W x2m H with the length of 1.6meter Cd depends upon Drag force, dynamic pressure and the ref. area of the object placed. My BC's are constant velocity at the inlet and zero pressure outlet. So, how does the Cd behave in this case as it is not depending on the area of WT am using? experimentally it increases in case of small WT area bcz of blockage ratio dues to walls etc. is it bound to happen numerically too. bcz in my case it not happening. Also, my object is placed far away from the inlet. will it have some effect on it. |
Ansys Beginner, How to Make a cross section in a specific plane in design modeler | arrman | ANSYS | 2 | January 22, 2020 08:30 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
cross section average | Paul | FLUENT | 0 | April 12, 2006 11:30 |
CFX:getting mass flow rate across a cross section | allamaprabhu | CFX | 1 | February 14, 2006 12:07 |
Cross section and surface area factor | Fabiana | CFX | 0 | January 9, 2006 23:51 |
