January 7, 2020, 11:16 |
Convergence does not stable
Hello dear friends,
I'm doing a vehicle simulation in Fluent 19.2. I put all of inputs and doing hybrid initialization then starting the calculations and my drag coefficient, drag force etc. graphs being up and down always change with the iteration values. When the calculation done the value which gives me last unit of the iteration. For example if I do 500 iteration, results give me 500th. values and I can not believe that results because it depends with the among of iteration how many iteration I entered. So if the graphs converge correctly I can believe the solution values. Please help If you have any idea about that problem. Editional Info: The X coordinate values are expected values, the problem is only with none converging. |
January 12, 2020, 06:38 |
#2 | |
Rep Power: 6 |
Steady or unsteady? If you are running a steady simulation, consider switching over to a transient simulation. Sometimes when the flow around a body is inherently unsteady, there is a possibility that the steady solver might not be able to converge, hence giving you the oscillating behavior that you mentioned. If you're already running a unsteady simulation, consider decreasing the time step( putting it as adaptive may help). of course this is assuming that your mesh is good, the y+ values are good and your choice of physics is correct (i.e. turbulence model etc) NonstopEagle |
January 12, 2020, 07:11 |
Dear NonStopEagle,
Firstly I thank you to reply my post. I'm working with steady withsome changing I got stable values but they are very low then I expected. So that reason I called my ANSYS desk. They told me those y+ values and meshing problems. I hope to solve with these info's. Thank you very much. Best regards. |
January 12, 2020, 08:13 |
#4 | |
Rep Power: 6 |
cheers NonStopEagle |
Low Mach number wing/body junction convergence | Zen | SU2 | 6 | May 3, 2019 04:51 |
Continuity Convergence Problem in CFX | cfd seeker | CFX | 2 | July 2, 2015 11:12 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 13:43 |
