How to deal with the error message in fluent? |
February 3, 2020, 21:09 |
Rep Power: 6 |
Dear all,
I am working on the ventilation rate of a room and just after completion of my calculation I have got this error message. Error: Error Occured during handling message in WorkBench: Generic Command Error Object: #f How to deal with this error message?? Thanks in advance. |
February 4, 2020, 03:20 |
Appears to be very generic
The message appears to be very generic and most likely has got nothing to do with your simulation. If you read the message, it mentions that it was unable to handle the message. That's alright as long as you have been able to converge and save your simulation and can post-process those.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
error, fluent |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 16:17 |
Why is Fluent unable to deal with my model at the micron scale? | dixylo | FLUENT | 4 | December 8, 2011 23:39 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
