February 6, 2020, 02:32 |
Pulsating Pressure User Defined Function
Vignesh
Rep Power: 6 |
I am working on a compressor piping related piping phenomena,where i want to give a pulsating pressure as a input which has a base pressure of 1724 kPa and a varying value of 68.9476 kPa with a frequency of 20 Hz. As I am a beginner I came to that i have to give UDF for this purpose,can anyone pls give the UDF code....
y=1724+68.9476(sin(2*pi*20*t)) Thank You.. |
February 6, 2020, 03:20 |
Alexander
Rep Power: 34 |
Ansys Fluent Customization manual
look for DEFINE_PROFILE macro
best regards ****************************** press LIKE if this message was helpful |
February 6, 2020, 03:22 |
UDF not required
You do not require UDF for this. You can use a transient profile. Format is given in Fluent User Guide. For your convenience, it is
((nameOfProfileWhateverYouWant transient 3 0) (time 0 1 2) (press 68 70 71.5) ) You can choose the name of the profile; no spaces are allowed in the name, you can use underscore, numbers, etc. transient is a keyword and has to be as it is. First number shows the number of data points. I have used 3 at time 0, 1, and 2 seconds. Units are all SI. Numbers can be real. Time values must be in ascending order. The last number in the first line is a boolean; can either be 0 or 1. 0 implies non-periodic. You can use 1 since you have periodic data. That way, you can provide data for only one time-period but still run the simulation for as many time-periods as you want. If that value is set to 0, then after the last time given in profile, value of the variable retains the last value. So, with the above profile, after 3 seconds, pressure will be maintained at 71.5 Pa. Use enough points to resolve the shape of the curve.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
