How do I specify the pressure at interior nodes? |
February 7, 2020, 23:33 |
CWL
Rep Power: 10 |
Does anyone knows how can I specify (fix) the pressures at the red boundary of the attached domain? I tried modelling just the C-D nozzle part, however, there are back flows at the outlet and something weird at the inlet. I have to attached the two zones outside the inlet and outlet. Yet, I am not sure how to specify the pressure at the now interior boundaries.
By the way, when using mass flow inlet boundary condition in an axisymmetric problem, should the mass flow rate specified be the complete one or I should only do half of it actual amount? Thanks for any thoughts. Last edited by cwl6750084; February 8, 2020 at 01:17. Reason: Include the attachment |
February 8, 2020, 16:43 |
Lucky
Rep Power: 66 |
Boundary conditions are applied to boundaries, not interiors. If you can't get the C-D to work, well then that's its own problem.
You specify the mass flow through the entire 2pi radian. |
February 9, 2020, 15:27 |
Too small domain
If the domain that you have shared the image of is complete, then it is too small and the flow reversal is expected. Right after the exit and before the inlet of the nozzle, there is sudden expansion and contraction, resp. You need to extend your model is both directions, i.e., upstream as well as downstream. Upstream, it should at least be 4 time the radius of the domain and downstream it should at least be 8 times.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 04:43 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 18:57 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
