February 10, 2020, 00:55 |
moisture material
Rep Power: 6 |
i want to model material that have few percent of moisture that put in melt tank.
then i want to heat it and material going melt and water is divide. so how can i model it? thanks with best regard |
February 10, 2020, 04:51 |
Melting and evaporation
Which model will you use for the melting of the material? Fluent has a solidification-melting model, however, that is not meant to be used with DPM; you have to write your own. With solidification-melting model, you can use VOF multiphase model and use evaporation-condensation model for mass transfer. If melting is of particles, then you have to write your own model; this can be based on in-built solidification-melting model, i.e., enthalpy-porosity technique or it can be a simpler one.
I'd recommend Forum so that others could benefit as well and suggestions don't have to be repeated.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
