2D Ahmed body turbulence model
Like Tree2Likes
  • 1 Post By Jerg
  • 1 Post By vinerm
Old   February 11, 2020, 12:55
Default 2D Ahmed body turbulence model
Jerg
Jerg is on a distinguished road
I have been simulating an Ahmed body in a steady stream. I have obtained wildly different results from using different turbulence models. All simulations have the y+ range of 0<y+<~1.
1) k-epsilon Realizable - Enhanced wall treatment:
The flow remains attached over the top of the body
2) k-omega SST - Low Re correction:
The flow separates at the curved front surface of the body.
Question: Which of these is "better"?
your loyal servant,
Jerg
lewis donnelly likes this.
Jerg is offline   Reply With Quote
Old   February 12, 2020, 05:55
Default Compare against exp. data
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Ahmed body is a rather well studied profile, so, there is a lot of literature available at various Re numbers. I suppose it would be better to compare against those. I have no experience with Ahmed body, so, I cannot comment on the accuracy of the predicted flow profile but validation requires some theoretical or experimental data or an experienced peer.
Jerg likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Problem with creating R file for SSG turbulence model Khozaei4000 OpenFOAM Running, Solving & CFD 3 April 26, 2022 16:02
6dof model - floating body flinde FLUENT 13 March 6, 2021 14:32
New turbulence model in OpenFOAM 5 with porosity scalar shinjanghosh OpenFOAM Programming & Development 0 January 15, 2020 00:06
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
