February 14, 2020, 08:24 |
How to set initial pressure
KevNo
Hello! I'm a newby in Fluent and have a question:
I want to model a countercurrent-flow tube heat exchanger. The flow through the tubes has an initial pressure of 250000 Pascal (temperature 40 degrees) - velocity inlet. The flow around the tubes has an initial pressure of 450000 Pascal (temperature 15 degrees) - velocity inlet. I have two corresponding pressure outlets. I want to simulate the flow and the temperature gradient (energy equation and viscous flow are activated). I'm using a pressure-based solver in the steady case. So, where can I set the initial pressure? In the inlets are only supersonic pressure and in the outlets backflow pressure given... Thank you! |
fluent, pressure |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
decompose dependent solution | arionfard | OpenFOAM | 3 | December 10, 2018 09:36 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
