Error in UDF for slip boundary
Like Tree1Likes
  • 1 Post By vinerm
Old   March 6, 2020, 06:31
Default Error in UDF for slip boundary
Amit Varakhedkar
av1399 is on a distinguished road
I have written a UDF for providing slip conditions to the airfoil wall using the Navier slip equation. After compiling the code, when I initialize the solution, I get this error: received a fatal signal (Segmentation fault).
I am simulating in series and the simulation is running perfectly for no-slip condition (without UDF).
Thanks in advance.
The UDF is as follows:
#include "udf.h"
#define del 0.0004 // wall slip layer thickness [m]
DEFINE_PROFILE(slip_velocity_x,t,i)
cell_t c;
real x[ND_ND], gamma, c_t, c_x, u, v;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
u = C_U(f,t);
v = C_V(f,t);
gamma = C_STRAIN_RATE_MAG(f,t); // tangential velocity component
c_t = gamma*del;
c_x = c_t*u/sqrt(u*u+v*v); // taking x component
F_PROFILE(f,t,i) = c_x;
end_f_loop(f,t)
DEFINE_PROFILE(slip_velocity_y,t,i)
cell_t c;
real x[ND_ND], gamma, c_t, c_y, u, v;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
u = C_U(f,t);
v = C_V(f,t);
c_t = gamma*del;
c_y = c_t*v/sqrt(u*u+v*v);
F_PROFILE(f,t,i) = c_y;
end_f_loop(f,t)
av1399 is offline   Reply With Quote
Old   March 6, 2020, 07:26
Default Slip Velocity UDF
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
There are a few issues with the code. Any macro starting with C_ is meant for cell center. And it requires cell index and cell thread, i.e., the arguments of C_ macros have to be of type cell_t and Thread *t where t belongs to a cell zone and not a boundary zone. You have to define a thread variable outside the loop, i.e.,
Thread *tc;
tc = THREAD_T0(t);
and incorporate following changes within the loop
c = F_C0(f, t);
C_STRAIN_RATE_MAG(c, tc);
Furthermore, you don't need the command F_CENTROID as well as its corresponding variable x because these are not required by the equation.
Last comment is about its applicability. It is not recommended to apply the velocity for a slip or partial slip condition. Better approach is to determine shear stress due to this slip and then apply that.
av1399 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
segmentaion fault, slip b.c., udf
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
