March 7, 2020, 09:53 |
Fsi
Vignesh
Rep Power: 6 |
Hello!!
I am solving a FSI problem. In this regard, I used a realisable k-epsilon model for solving the problem. In ANSYS Fluent solver, METHODS section which are all diffusion terms and which are all convection terms? so that I can specify the methods to them as per the journal I referred. I have also attached the screen shot of the journal image with this. Thank You Schemes1.jpg |
March 7, 2020, 16:54 |
Discretization
The mention in the journal does not imply the available choices. Diffusion terms in Fluent are always discretized using central-difference scheme and, consequently, is second-order accurate. The only option related to diffusion is choice of gradient calculation and limiters. The discretization schemes available under methods are all relevant to convection terms to determine the flux at the upstream faces or for pressure interpolation.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 20:43 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 04:14 |
initial file for fsi modeling? | mortazavi | CFX | 0 | July 21, 2009 02:06 |
fsi | sun | Siemens | 8 | January 19, 2009 23:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
