Write profile using TUI for multiple variables |
January 17, 2022, 10:16 |
Pier Angelo
Hi all
Can anyone please help? What is the syntax for writing profiles for multiple variable using TUI? Say I want to write a file named as out.prof for pressure, x,y and z velocity on my boundary named as "inwall". The core below is my understanding. /file/write-profile out.prof inwall , pressure, temperature, x-velocity, y-velocity, z-velocity I have tried various combinations, with and without the ",". Thanks in advance Pier |
January 18, 2022, 02:20 |
Alexander
Rep Power: 34 |
file write-profile out.prof inwall () pressure temperature x-velocity y-velocity z-velocity ()
best regards ****************************** press LIKE if this message was helpful |
January 18, 2022, 08:20 |
Pier Angelo
Obviously I haven't' tried the right combination.
thanks a lot, that works. |
January 18, 2022, 10:56 |
Lucky
Rep Power: 65 |
To explain what is happening... It has nothing to do with commas
You are telling Fluent to write a profile on a list of surfaces and you always need to terminate the list with a pair of parentheses (). In your case, you have only one surface (named inwall). Likewise, you need to provide a list of field variables you want to write and terminate that list with (). Any time you enter multiple names for a prompt (i.e. pressure and then temperature), you can be damn sure a pair of () should follow. |
fluent, multiple variables, profile data, tui |
Initialize Profile Data Variables | aero_head | CFX | 5 | April 25, 2021 19:07 |
write profile - journal file | mateus | FLUENT | 1 | June 13, 2006 04:26 |
howto write step velocity profile with expressions | prabhu | CFX | 2 | May 23, 2006 09:41 |
How to request cfx to write variables at a point? | Uday | CFX | 1 | February 5, 2006 23:42 |
write profile - different length of columns | Ralf Schmidt | FLUENT | 1 | July 18, 2005 06:40 |
