April 7, 2020, 02:44 |
Internal pipe temperature setting
aya
Hello
I am simulating a double tube structure. I want to set the outer tube to 600K and the inner tube to 900K, but the inner tube can only set the temperature at the end. What is wrong? FLU 1.png FLU 2.png FLU 3.png |
April 7, 2020, 07:34 |
Temperature Setting
What do you mean by setting the temperature? Do you mean initial temperature, i.e., temperature at time 0 s and then you want to observe how it evolves in time? Or do you mean temperature at boundaries? If it is none of these, then most likely you want to fix the values. This option is available under Cell Zone Conditions. Do note if the cell zones are solid and you fix the temperature, then there is no point in having the cell zone itself. You can just delete the cell zone and apply that temperature as boundary condition.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Bulk temperature expression gives value below inlet temperature for half the pipe | Shomaz ul Haq | CFX | 3 | June 21, 2017 03:40 |
externalWallHeatFluxTemperature - Temperature internal domain | SarahLee | OpenFOAM Running, Solving & CFD | 2 | April 20, 2017 15:38 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
Bulk temperature along the length of the pipe | Ochenapothik | FLUENT | 0 | February 12, 2014 02:59 |
wall temperature setting | nianqi | CFX | 0 | October 16, 2006 06:53 |
