Evaporation
Old   April 8, 2020, 13:44
Default Evaporation
Ileayo
Ileayo is on a distinguished road
Dear all,
PLEASE I NEED HELP!!!
I am simulation evaporation in horizontal pipe.
Theoretically, the temperature difference (Twall - Tsat) should become constant after the flow attains steadiness.
In my own case, I could not get a stable constant temperature difference, the temperature difference keeps increasing as the simulation continues. This I experience with both the UDF and the inbuilt Evaporation-Condensation (Lee) model.
Surprisingly, I got a constant temperature difference after some time when the simulation attains steadiness with a reduced length (about x 0.1) the original length.
My boundary conditions are mass flow inlet, pressure outlet, heat flux wall boundary condition using SST k-w and VOF model.
Please kindly advise me sir and ma.
I will indeed appreciate your expert advice.
Thank you in anticipation.
Ileayo is offline   Reply With Quote
Old   April 9, 2020, 04:14
Default Constancy
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What is the reason for assuming that the temperature difference becomes constant. T_{wall} - T_{sat} can always be constant if user applies temperature at the wall and keep the pressure constant. However, if heat flux is applied at the wall, which is the case for you, it will keep on supplying heat to the system, i.e., system will keep on gaining the heat. If the pressure is constant and consequently the saturation temperature is constant, the wall temperature will keep on increasing in line with increase of fluid temperature. The profile may become constant but not the value.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 12, 2020, 05:52
Default Temperature or heat flux wall boundary condition
Ileayo
Hi Vinem,
Thank you for your reply. I am grateful. I actually thought that both temperature or heat flux wall boundary condition should give constant temperature difference after the flow attains steadiness.
evaporation, fluent, lee model, twall - tsat, udf
Evaporation model in ansys Fluent 12.1 oldisbest Fluent UDF and Scheme Programming 12 March 26, 2020 09:11
Water Surface Evaporation sunggun1212 FLUENT 3 January 11, 2020 04:12
Evaporation due to Heat Transport using InterFoam (Correct Implementation?) ovie OpenFOAM 14 August 3, 2019 07:00
Rate of evaporation | Hertz–Knudsen equation | Chloroform Evaporation cfd_user_pune Fluent Multiphase 0 October 26, 2018 05:44
Liquid Evaporation Model Error in OF 2.3.0 brbbhatti OpenFOAM 11 June 16, 2014 09:40
