Parabolic velocity profile of premixed combustion |
April 18, 2020, 08:09 |
Koo How Boon
Rep Power: 6 |
Hi, there.
I am doing the premixed laminar flame recently. When I was dealing with constant velocity of air-fuel inlet velocity (0.35m/s), it works perfectly fine. However, when I applied parabolic inlet velocity with max speed of 0.35 m/s, it becomes something like this 0.35 ms UDF(axial-velo), 60%CH4-40%CO2, 298K, 500 iterations.JPG The radius of my air-fuel inlet is 3.775 mm, and the co-flow inlet is formed by pure nitrogen with 0.05m/s. Here is my output velocity profile: ((fuel_air_inlet_fluid_flow__fluent__ point 38) (x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ) (y 0.0037253289 0.0036259866 0.0035266448 0.0034273025 0.0033279606 0.0032286183 0.0031292764 0.0030299341 0.0029305923 0.00283125 0.0027319081 0.0026325658 0.0025332235 0.0024338816 0.0023345393 0.0022351975 0.0021358551 0.0020365133 0.0019371711 0.0018378289 0.0017384868 0.0016391447 0.0015398026 0.0014404606 0.0013411185 0.0012417763 0.0011424342 0.0010430921 0.00094375003 0.00084440788 0.0007450658 0.00064572366 0.00054638158 0.00044703949 0.00034769735 0.00024835527 0.00014901315 4.9671053e-05 ) (axial-velocity 0.009026316 0.027078947 0.044409472 0.061386317 0.07796526 0.093851581 0.10938421 0.12448947 0.13893157 0.15301999 0.16665158 0.17964947 0.19229369 0.20445158 0.21600527 0.22720526 0.23788947 0.24799895 0.25775474 0.26696527 0.27563053 0.2839421 0.29167894 0.29890001 0.30576736 0.31203052 0.31780738 0.32323053 0.32802001 0.33235264 0.33633158 0.33964738 0.34253579 0.34507054 0.34691262 0.34835684 0.34944737 0.34981579 ) ) Is that any problem in my parabolic velocity profile? |
April 20, 2020, 04:16 |
Velocity Profile
The profile you have is correct. The contours are of temperature, hence, not a validation of the profile. You should look at velocity contours and plot the profiles at various axial locations. Temperature and velocity contours will look same only when they have same boundary condition, which is not the case here. Default and most appropriate condition for velocity is no slip, i.e., 0 velocity at the wall. However, default for temperature is adiabatic, i.e., the gradient is 0 not the value. So, the field is expected outcome.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
UDF parabolic velocity profile issue | Kenzhia3310 | FLUENT | 3 | April 7, 2020 11:20 |
Parabolic velocity profile in 3d with UDF | mmk3818 | Fluent UDF and Scheme Programming | 1 | August 21, 2016 18:35 |
Parabolic velocity profile in a rectangular channel | nithishgupta | OpenFOAM Running, Solving & CFD | 3 | October 30, 2013 05:39 |
unsteady parabolic velocity profile | smorls | Main CFD Forum | 0 | April 9, 2013 12:22 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
