April 19, 2020, 11:15 |
Cfd post velocity-velocity in stn frame
Hüseyin Can Sülük
Rep Power: 6 |
Hello guys
I have done a simulation of savonius wind turbine with two domain inner rotating 20rad/s outer stat. inlet 10m/s Sliding mesh k-epsilon realizable scalable In cfd post there are two options for velocity velocity-velocity in stn frame when i choose velocity results is not looking right it seems there is wall between rot.and sta. domain but it seems normal in velocity stn frame what is the difference between them ? |
April 20, 2020, 04:26 |
Frames
Since two different reference frames can be defined for this problem, you can plot velocity or any other field in both of these frames. Stationary implies inertial reference frame, such as, observation by a person standing and looking at the rotating turbine. Another one is the frame of the turbine itself. A person standing at the center of the turbine and rotating with it will observe different field.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 20, 2020, 13:03 |
#3 | |
Hüseyin Can Sülük
Rep Power: 6 |
April 20, 2020, 13:26 |
Chart
Plot a transient chart. Then export the graph and calculate average over time.
Other option is to write a script using Perl Power Syntax in CFDPost, but the former option is simpler if you have never done programming in Perl.
Vorticity/ velocity curl in STN frame | EthanWalker | FLUENT | 1 | December 3, 2018 16:07 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Plotting Radial Velocity and Tangential Velocity in CFD Post | ashtonJ | CFX | 5 | July 13, 2015 02:49 |
Parallel process & CFD POST | jypark | FLUENT | 2 | August 14, 2013 23:49 |
Stn frame and radial velocity component in NREL | mohammad | CFX | 1 | October 25, 2011 10:13 |
