Parabolic Trough Solar Concentrator Simulation |
April 29, 2020, 21:54 |
Andrew Saad
Rep Power: 6 |
Dear all,
I'm simulation a 3D parabolic trough solar concentrator on ANSYS Fluent bur I have a problem defining the parabolic trough itself as a reflective surface so the solar radiation that it's receiving it has to be reflected back and concentrated on the water tube. So how can I do so? Thanks in advance, |
April 30, 2020, 05:08 |
Problem Definition
This appears to be an Optics problem and not Fluid flow scenario. Are you sure Fluent is the tool you wish to use? You can do it using Radiation Model but if the objective is only to study optics, then better use some other tool because Fluent will be very slow for this purpose.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 1, 2020, 21:40 |
Andrew Saad
Rep Power: 6 |
Thanks for your reply.
I didn't mean in optics manner but I want to make sure that the parabolic trough reflects the radiation to concentrate it on the water pipe and I did use the radiation model already but I'm only asking if there is anything that I can do to make sure that the parabolic trough reflects the radiation as the radiation reaches it. Thanks again for your time |
May 2, 2020, 16:24 |
Angular Dependence
Then you have to consider angular dependence in radiation modeling, i.e., specular surfaces and not diffuse. By default, all walls behave as diffuse walls.
Parabolic solar collector | belkhir72 | FLUENT | 0 | March 10, 2017 18:33 |
Simulating Heat Transfer in a Parabolic Trough concentrating Solar collector receiver | Ash_Mech_Eng | FLUENT | 1 | December 10, 2012 11:02 |
[ICEM] Meshing of a parabolic trough | Bazinga | ANSYS Meshing & Geometry | 31 | June 19, 2012 08:38 |
Modeling Solar parabolic Concentrating Cells | amit.at.msu@gmail.com | FLUENT | 0 | November 18, 2011 11:02 |
IdeasUnvToFoam Bug amp Fix | benru | OpenFOAM Bugs | 42 | November 13, 2009 07:59 |
