Combustion stops after a few 100 iterations.. |
May 1, 2020, 02:16 |
Lee Jo
Rep Power: 6 |
Hi...
I'm modelling EDC , species transport combustion of cryogenic fuels (CH4/LOX) under trans critical conditions.. I montior the temperature contours (using animation) and found that flames are produced...the flame shape changes after every 10 itreation... The residuals are good and when it is nearly converged there is no combustion occuring, only mixing of fuels.. Even when I patch a high temperature the flame shape appears for some iterations but it goes away...I have tried to patch multiple times...but each time the flame disappears... Does anyone know why this is happening??! |
May 1, 2020, 15:44 |
Isat
Are you using ISAT or some other mechanism to increase the speed? If yes, then patching with high temperature is not a good idea. Rather, try to purge the table and let it rebuild.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 1, 2020, 21:58 |
Lee Jo
Rep Power: 6 |
May 2, 2020, 11:57 |
Same issue with combustion
Krutika Appaswamy
Rep Power: 6 |
I am having the same issue with combustion but while using PDF transport method.. Any idea why this is happening? Thank You!
May 2, 2020, 16:33 |
Isat
Clear the table but do not patch. Patching is not always helpful. In case you do not see any combustion, then patch.
May 4, 2020, 04:09 |
#6 | |
Lee Jo
Rep Power: 6 |
So I patched with high temperature (2500K)...I observed flames for a few 50 iteartion...then it began diassapering again and became like the original flameless contours... |
May 4, 2020, 09:11 |
Moritz Kuhn
Rep Power: 17 |
I have no experience with modeling of combustion. But it seems that the flame depends on a certain temperature level. With patching you hook the temperature of your domain to that level, only for the starting point of your simulation.
Check your boudary conditions, try to increase the temperature of your inlet streams and/or of your walls, to avoid a cool down of your domain. |
May 5, 2020, 08:33 |
Table
Then the issue is most likely with the generated table or with turbulence interaction. It is possible that fine-scale time is too small. You can try with reduced acceleration factor, make it close to 0.
October 7, 2020, 12:14 |
#9 |
Krutika Appaswamy
Rep Power: 6 |
I have been having the same issue with combustion and I remember reading that reducing the integration parameters initially helps in ignition. I remember something like this worked for me then but I am unable to get it to work now. I was wondering if that is true and if so, how to start the case to ensure sustained combustion. Thank you! |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
