How to keep fluid flow continuity between different zones? |
May 8, 2020, 04:28 |
Rakesh T
Rep Power: 6 |
Because of geometry complexity , i have done meshing dividing the geometry into different zones. But each zone need to have continuity with fluid flow, when i come to fluent there are "walls" been created between each zone.
So, I changed them to interfaces which are now becoming unassigned interfaces. Then by selecting pairs and clicking "auto create" i could make them assigned. How can i create there is fluid motion continuity between two zones out of 4 options available(coupled,mapped,matching,static) ? If the above procedure is wrong, please give me right way. Thanks, Rakesh |
May 8, 2020, 05:08 |
Options
For flow continuity, you don't need to select any option. Just interfaces will do.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 8, 2020, 05:37 |
Walls
The interfaces are created because the meshes of the coincident boundaries are not same. Since those are not same, there are always some portions that are non-overlapping. Those portions do not have any complimentary parts, so, those can only be walls. But those portions are usually small and can be ignored.
Please us Forum instead of PM so that others could learn and I could be corrected in case I am wrong.
May 8, 2020, 06:26 |
Rakesh T
Rep Power: 6 |
1. Initially, there were walls between different zones.
2. I changed them to interfaces coz they may act as stationary wall or moving wall which doesnt solve flow continuity between them. 3. Now, they are "unassigned interfaces" which i have to make assigned. So, i used auto create option, which made them assigned. 4. Now, they are assigned interfaces which are not a problem, but along with it walls were auto created for each zone again with the new name i have given in "interface name prefix" ...... The problem of wall continues. Please help!! |
May 8, 2020, 06:40 |
Walls
Please read my previous post carefully. You can ignore those walls.
May 8, 2020, 06:52 |
Rakesh T
Rep Power: 6 |
Thank you so much.. Got cleared
I have some other doubt. If we need to create a Fluid solid interface boundary condition in Transient Mechanical, should we use a face selction that is in contact with fluid domain or the body selection of the deformable structure |
May 8, 2020, 06:59 |
Mechanical
I am sorry I don't know much about Mechanical but no flow equations are solve in Mechanical, hence, there won't be any fluid zone. There are fluid elements in Mechanical though.
May 8, 2020, 07:01 |
Thanks
Rakesh T
Rep Power: 6 |
No problem.Thanks again for ur time
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
