May 15, 2020, 22:28 |
Not being able to get results
Jorge Valdivia
Rep Power: 5 |
I am an undergraduate student, I'm trying to simulate the flow field on a model I made of an aeronatuical combustor. The thing is that I am not considering combustion, just the hot flow and the cold flow around the material (image). My model is compressible and turbulent k-omega (according o a tutorial I saw). I have 3 inlets 2 of cold flow (580 K) of 0.79 and 0.82kg/s, and a hot one (2300K) of 0.414kg/s. The fluid is air. I don't know why fluent is not responding when i turn on the ideal gas feature in material properties. It worked well when the density was fixed. I have refined my mesh to 6 million cells and now my system isn't even able to initialize with hybrid initalization. What could be the problem? Is ANSYS not reading parameters with such high. I will post the images. [IMG] https://imgur.com/a/N0UDQ4H [/IMG] Edit: the pressure on the inlets is 9.5 atm Last edited by Jorge Valdivia; May 16, 2020 at 00:22. |
May 16, 2020, 06:14 |
Fluent's Response
What do you mean by Fluent is not responding?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 16, 2020, 09:19 |
Jorge Valdivia
Rep Power: 5 |
Hi Vinerm,
I mean that the iterations are taking to much time to calculate the parameters. Much of the time this problems have to be with pressure limitations and turbulent viscosity ratio limitations, and then eventually fluent detects a floating point exception when the calculations are advanced (in coarsed meshes). I have tried different sizes of elements. Thank you for replying. Jorge |
May 16, 2020, 10:04 |
Ideal Gas
With ideal gas, you should set up operating pressure as 0 and use absolute values of pressure at inlet and outlet. Try with a coarser mesh. If you are using cooling holes in the liner, then ensure that there are at least 18 nodes along the circular edge. Furthermore, is not meant for such applications, but for wall bounded flows. Though you are not modeling combustion still the mixing of cold gas with hot gas is better predicted with . Or use SST .
May 16, 2020, 10:16 |
Jorge Valdivia
Rep Power: 5 |
Thank you, I will try with those turbulence models also I am reading the faq about fluent, very helpful. I am a new member so maybe my thread was not aligned with the community standards. I will post a more specific new thread when I encounter a more specific problem. I feel really optimistic about my simulation now that you gave me that advice.
Regards, Jorge |
combustor, compressible, divergence, fluent, hot flow |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
lid driven cavity varying results | yasmil | OpenFOAM Running, Solving & CFD | 2 | October 6, 2016 21:42 |
interFoam simulation yields inconsistent results for alpha1 surface | Ralinus | OpenFOAM Running, Solving & CFD | 8 | January 13, 2014 08:54 |
CFD results not close to experimental results | cider | STAR-CCM+ | 0 | July 8, 2013 07:53 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
