May 5, 2020, 02:54 |
roughness height
saphana
Rep Power: 6 |
hello
i working on simulation a gravel bed open channel flow as rough bed but when i reach to determine wall B.C i do not know which value should i put for roughness height and roughness constant ,plz can any one help me |
May 5, 2020, 06:40 |
Roughness Height
Roughness height that Fluent expects is sand-grain roughness, i.e., if whole of the roughness was uniform. If you values for , then you can determine the roughness height to be entered in Fluent.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 9, 2020, 03:02 |
saphana
Rep Power: 6 |
thank you sir ,but i'm working on non uniform gravel bed surface with different grains size in this case how can i determine the roughness height (i.e.what value should i used) and what do you mean of this "
If you values for Ra, then you can determine the roughness height to be entered in Fluent." i didn't understand sir can you explanation more,please with regards |
May 9, 2020, 07:00 |
Surface Roughness
You can use a roughness profile if roughness varies with position. However, the roughness measured using experiments or in the fields is not useful for modeling, not in it's original form. It needs to be converted into sand grain roughness. Quite possible that the new versions of Fluent accept measured roughness values as it is but you have to check that in manual.
May 9, 2020, 10:52 |
saphana
Rep Power: 6 |
sir i'm using version 16.1 is it has more difference from new versions and are you advice me to use last version for my case.
May 9, 2020, 16:24 |
v16.1
Newer versions have roughness but only for icing simulation, applicable to nacelle icing primarily. So, the only option you have is to use sand grain roughness and that is available in both 16.1 and newer versions. However, newer versions allow roughness to be larger than the mesh size without resolving the roughness with fine mesh.
Setting of Roughness Constant and Height | Sing | FLUENT | 7 | June 23, 2021 14:26 |
Roughness height | Goutam | FLUENT | 8 | February 17, 2017 06:55 |
UDF: for the setting of roughness height | maximus | FLUENT | 1 | September 10, 2014 16:20 |
atmospheric roughness height | Alain BASTIDE | Siemens | 5 | December 30, 2002 05:26 |
atmospheric roughness height | Alain BASTIDE | Main CFD Forum | 0 | December 27, 2002 16:32 |
